Results 1 to 10 of 12
Thread: I need advice! :)
    Minneapolis, MN
    I swapped out mine for a used one back in August. I scraped away or converted any surface rust I found before putting it on. Very pleased with the results.
    Jan 2008
    Sweden
    Thanks to you all, I just ordered the used original!
    Jan 2008
    Sweden
    Quote Originally Posted by BennyM View Post
    Benny, did you weld it on @ the rear silencer or?
    Minneapolis, MN
    I actually replaced the middle and rear as one glorious used chunk that I got off a guy for $75. The only welding I had to do was on the other side of the cat as I decided to switch down-pipes at the same time.
    Check out my old post here: http://www.bimmernut.com/forum/showt...27055#poststop
    Quote Originally Posted by Bo525i View Post
    Tried building one once. Seen a few do it also. All fail the quality or rear seat drone test. Knowing that I bought a new Eissenmann for the M50. About USD $300 here in Oz. Got a new muffler too for about the same dollars. They bolt together with two special joiners- and bolt up to the cat directly. Sounds nice, works perfectly, car runs like new . M50 ECUs like to know their combustion is good.
    Beware, 525 has three or more tailpipe ocnfigurations so it can be trouble mixing up one muffler with another resonator.
  1. Cat advice please!
    Last Post: 12-10-2007, 01:40 PM
  2. Lkm advice
    By compmore in forum 5 Series BMW
    Last Post: 04-11-2007, 08:43 AM
  3. Need Advice Please!
    By 1995 525i in forum 5 Series BMW
    Last Post: 07-13-2006, 12:55 PM
  4. Need advice on 2nd car!!!!! HELP
    By James in forum 5 Series BMW
    Last Post: 08-30-2004, 06:29 PM
  5. Thanks For The advice
    By LuF in forum 5 Series BMW
    Last Post: 03-03-2004, 08:35 PM
