Originally Posted by
BMW4LIFE
5) What kind of spark plugs should I use? I have the platinum +4 right now but I hear that these cars were no designed for that kind of plug and it may run too cold...does that make sense?
if so what kind of plug should I use?
M50's don't like those style plugs. Factory plug is a Bosch F8LDCR for pre-1/93 build, Bosch F7LDCR or NGK BKR6EK for post 1/93 build date. As you don't list your build in your car description under your user name or in your sig I can't say which plug you need.
Will say that it's hard to walk into a parts store and find those plugs. Dealer is probably the only one that'll stock them. Anyone that keeps stock of them is going to want $10/each for 'em.
I've found in a friend's M50 & my M60 which both call for the same plugs that the E3 brand plugs actually work better than the stock Bosch plugs do. And you can find them just about anywhere for $6/each.
Tried the E3's in my M-Sport first as I needed new plugs and had read up a bit about the E3's and they sounded like they'd work well. They did. Smoother running across the board. Slight feel of power improvement.
When a friend thought she needed new plugs in her '95 525iT (after buying the E3's and pulling the old plugs I found that they didn't need to be replaced) I went and got the E3's for it. It ran much nicer than it had on the proper Bosch plugs. Noticeably smoother and better power. She thanked me profusely a couple of days later as she was much happier with the engine with the E3's in it.
Proper E3 plug for an M50 is the E3.64.
