Best to just drain the fluid at the lowest point in the system if you want to efect a full change. I think that is the lowest line on the steering box, but it might be the pump, just look. Of course if the car was originally a Pentosin car and was converted then there might be a problem..
Easy to do, just look at the lines going to the steering box. Do any follow the (US drivers side) rail back under the cabin to the rear? LAD deleters usually just replace the rear shocks and join the hydraulic lines at the back near where they reach the subframe. Sometimes they leave the height switch which operates off the sway bar and even the accumulators, both of which are very obvious.
Or do a VIN check. Or goto www.realoem.com and enter yor car's VIN to see if the parts listings show LAD components as valid for your car, or simply the conventional shocks. This is in no way as reliable as looking in the flesh- and realoem is often incorrect/vague or simply hard to work out
