Results 1 to 4 of 4
Thread: Gasoline Smell
    DMahon Guest
    Default Gasoline Smell
    I have a 1993 325is. Lately, I've noticed that after I fillup the tank, I get a very concentrated smell of gas fumes. This smell continues until the tank gets below 3/4 of a tank. Then the smell disappears. It is bothersome because I have an attached garage and the smell overwhelms the house. I've checked for leaks both around the gas tank and the engine...don't see anything.
    Has anyone experienced something similar or have any suggestions on what I can do short of bringing it in for a mechanic to look at?
    Thanks
    D. Mahon
    Dunlap Illinois
    I've heard that topping off the tank is a way to destroy the activated carbon canister filter on BMW's, and will result in the tank not being able to properly vent cleanly. Check all the vent hoses to the canister filter and make sure they are connected, but first, re-check all your fuel hoses for leaks. I'd park the car outside until it was fixed, one spark with concentrated fumes in your garage will spell disaster for your whole family. Get it checked PDQ.
    gas smell on a e36 is usually a on top of the tank problem, ether a o-ring on one of the two senders has died, or the **** designed plastic/rubber pressure line from the right side (fuel pump) is starting to leak directly infront of the tank where the steel pressure and return lines start and the rubber lines from the tank end. being fuel level related id guess it's a o-ring, theres a sending unit on each side of the tank accessable from under the back seat, pump on right gauge on left
    Unregistered Guest
    Default I had the same problem with my 94 325i
    The problem was with a cracked ring or something under the hood. I'm a girl so I don't pay attention to the names of these things. However, when I filled up my car I could smell gas and when it was a 3/4 tank I couldn't smell gas anymore. Dealer fixed it after I complained that they sold it to me that way.
  1. What Gasoline do you put in your E34?
    By Fetch in forum 5 Series BMW
    Last Post: 10-19-2006, 06:08 AM
  2. the oil smell like gasoline
    By amerjubran in forum 5 Series BMW
    Last Post: 05-08-2006, 04:31 PM
  3. Gasoline smell at first starting
    By Al Gray in forum 5 Series BMW
    Last Post: 02-05-2006, 02:38 PM
  4. Gasoline smell
    Last Post: 01-13-2006, 12:02 AM
  5. OT: How do you get gasoline smell out of carpeting?
    Last Post: 11-03-2005, 06:53 AM
