Either there is air in the system or fluid is getting past the seals. You will certainly notice fluid loss. Bleed nipple clogged?
Hello,
We tried to bleed the clutch as the pedal feels spongy at times. But the funny thing is no fluid is coming out! . We did the usual 2 persons bleeding procedure.
Anyone had this issue before?
the bleed nipple is like new. not a single drop of fluid loss. It is totally bizarre.
I first did it alone and then went to a mechanics with a pit for a clear view. He couldn't either. I'm puzzled that's why I'm asking maybe one of you already had this puzzle.
To bleed, engine is off and reservoir cap is screwed right?
The car still drives and shifts fine
This might help:
http://www.bmwe34.net/E34main/Mainte..._hydraulic.htm
a shop told me it is the clogged slave cylinder that is leaking inside the trans. hopefully not expensive and easy DIY job
