Results 1 to 10 of 13
Thread: m60 timing cover oil leak
    Nov 2006
    central coast nsw
    Default m60 timing cover oil leak
    94 540I 308,000 kms
    Leaking a bit of oil and am told it's from the timing cover.Local guys say it's a big job and it may even be easier to pull engine to do it.
    Just wondering how big a job it would be to do with engine in and what else I should look at checking/replacing if I'm gonna do it.The car has 308,000 kms mostly highway miles and i intend to keep it long term
    geoff b
    Apr 2008
    Illinois
    I just did valve cover gaskets in my 540i/E34 a month ago. You dont have to pull out the engine. I wouldnt describe it as piece of cake but though its not a hard job at all, it took me about 3 hours for each bank, most of the time spent was in cleaning the sealing surfaces (the cover grooves) as it contained lots of deposits on it.
    The hardest part was removing the power steering/ASC oil canister hoses (the large hoses) to get access to the area to remove and install the driver's side cover easily.
    Check out these links!
    http://www.bmwtips.com/tipsntricks/v...valvecover.htm
    http://www.bimmerboard.com/forums/posts/264840
    http://www.bimmerboard.com/forums/posts/124059
    Jan 2008
    Sweden
    I did my valvecover gaskets and I didnīt remove any power steering/canister hoses, just all the connections on top (watch out for the little clips attached to the wiring box ) using this as a guide: http://www.bimmerboard.com/forums/posts/124059
    East Brunswick, New Jersey
    He has a leak on the timing cover, not the valve cover. Timing cover removal is not for the light hearted.
    '01 540it, 6/01
    '03 325i 5 speed, 9/02
    '10 535ix. 9/09
    '10 mini 6 speed
    '15 mini countryman 6 speed
    Jan 2008
    Sweden
    True that.. Upper or lower, daunting challenge!
    Apr 2008
    Illinois
    Quote Originally Posted by yaofeng View Post
    That's true! I didnt read the message very well
    Apr 2008
    Illinois
    Quote Originally Posted by Bo525i View Post
    Yeah, in many E32/E34s you dont need to remove any hose, but mine equipped with ASC+T(one with LAD big oil canister), there is a big hose come across the driver's side valve cover lower edge making the job almost impossible without this hose removal.
    Nov 2006
    central coast nsw
    guys its not the valve cover gaskets but the front timing cover i need the info on
    Don't just rely on the words of your indy. Verify yourself the leak is from the timing cover. The much more common occurrence is of course from the valve cover. Open the valve cover to see if there is oil in the spark plug holes. If there is the leak is from the valve cover. Of course this is not to say your timing cover is not leaking. But replacing the timing cover gasket is a huge undertaking you do not want to take lightly. If it is the case your indy is correct the engine may have to be removed.
    Look at the pictures. I am not sure you can do it without removing the heads either.
    '01 540it, 6/01
    '10 535ix. 9/09
    '10 mini 6 speed
    May 2006
    NH
    I had been told my LOWER TC Cover gasket was leaking and believed that for a long time. It turned out there were several leak points but none from the Lower Timing Chain cover gaskets. The upper Driver side was leaking as well as Valve Cover gaskets and the oil filter housing lines to and from the block and their O-rings.. I also had power steering hose leaks . If you're forced to have a shop do it it ran me around $1,000 for the oil leaks where just the Upper timing chain cover gasket was done
    pasted from an invoice;
    REPAIR ORDER
    Print Date : 02/17/2009
    1995 BMW - 540i
    MFG Date : 12/13/1994
    Last Service : Current Odometer : 273438 Previous Odometer : Elapsed Mileage :
    Engine : 4.0L, V8, VIN (3)
    LABOR - INSPECT FOR LEAKS
    11 12 9 069 872 Valve Cover Gasket Set without Washers 1.00 29.51 29.51
    11 12 9 069 871 Valve Cover Gasket Set without Washers 1.00 29.51 29.51
    11 12 1 437 395 Valve Cover Seal Washer 22.00 1.12 24.64
    11 14 1 433 305 Timing Cover Gasket Set 1.00 12.40 12.40
    11 14 1 433 306 Timing Cover Gasket Set 1.00 12.24 12.24
    12 13 1 730 521 Spark Plug Connector 8.00 13.44 107.52
    3199. Spark Plug BKR6EQUP NGK 8.00 14.78 118.24
    7402 Spark Plug FR 7 LDC+ 8.00
    LABOR - TIMING CASE COVER 578.00 578.00
    LABOR - POWER STEERING 51.00 51.00
    Estimated Parts $25.00
    Subtract $67.00 to use Bosch FR 7 LDC+ Spark plugs instead of the NGK
    189099107 Cleaning Solvent - Aerosol 14.39oz Can 3.00 5.44 16.32
    Revision # 1, Previous Estimate Amount - 13.60, Additional Cost - 1004.38, Revised Estimate - 1017.98
    Parts: $375.38, Labor: $629.00, Sublet: $0.00, Taxes & Fees: $0.00
    Date-02/17/2009, Time - 05:14PM.
    Parts : $ 375.38 Labor : $ 629.00 $ 0.00 Total : $ 1,004.38
    that was for both sides... the oil filter lines were done at another time and were a few hundred dollars, power steering was around $600. I also had a Transmission selector shaft seal leak and had that repaired as well for a few hundred but had a UUC short shift installed then too and since the exhaust connecting flange was broken when the exhaust was removed for that a little more ..oh there were other things done as well . Water Pump+ T-Stat, a new pulley, new serpantine belt, new lower oil pan gasket, resealed the Intake manifold and a new Intake manifold cover and gasket. new throttle body gasket.... think about things which you can replace while doing this leak that you'll most likley end up needing if you plan on keeping and driving it.
    Interestingly enough I rolled past 320,000 miles last night. Just about 50K miles since this work with no leaks so I consider myself to have been fortunate it wasn't the Lower.
    1995 540i Manual build 1/95
  1. M30 oil pan and timing cover gaskets
    By Ken35i in forum 5 Series BMW
    Last Post: 11-19-2007, 02:15 AM
  2. Timing cover gasket?
    Last Post: 11-29-2006, 08:20 AM
  3. 535i timing chain cover
    Last Post: 08-28-2006, 12:19 PM
  4. timing chain cover
    By jjdickm in forum 5 Series BMW
    Last Post: 04-13-2006, 03:23 PM
  5. Cam and Timing Cover gaskets leaking?
    Last Post: 04-04-2006, 09:26 AM
