Results 1 to 10 of 19
Thread: thrust arm bushing f**c**d up
    Sep 2006
    Default thrust arm bushing f**c**d up
    Hey guys,
    Just had Canadian Tire press in a new bushing in my brand new upper control
    arm(thrust arm). They pressed it in crooked and its all cock eyed. They say they can't fix it and that an alignment will compensate for it.
    I don't agree but there are no dealerships open here today to confirm this with. To me this seems pretty critical to keep caster, camber, and toe correct, and I know bloody well that there alignment just adjusts the toe.
    Any input would be appreciated, I am just about ready to go postal!
    Edward
    As you know, you'll be stressing the bushing and it won't last as long. It will likely drive fine, but it just won't last. Funny, last time I asked CT to do something (install springs on honda struts that I handed to them), they screwed it up. Junior didn't line up the strut mount with the marks I made on the strut.
    They should be pressing out the bushing out and getting you a new one.
    Dave
    Evanston, IL
    Default Where are you located?
    Sep 2006
    I am in Ottawa.
    Edward
    Oldham, England
    Quote Originally Posted by Dave M View Post
    Dave
    x1
    If you can make them do it is perhaps another matter
    Apr 2008
    Illinois
    This bushing is notorious for failure even when it's installed correctly. So I doubt it will last too long this way. If I were you I'd ask them to redo it.
    Sep 2008
    Gold Coast, Australia
    Yeah sounds like these people are lazy. Please make them install the bushing, other people have problems even with correctly installed ones.
    Evanston, IL
    Default I was going to say find a dealer...
    ...but I do not know any there.
    A competent machine shop can press in the bushing as long they know the orientation. This also means that the thrust arm must be off the car for them to do so. If CT can't do this job right, they are not likely going to install it right either.
    Quote Originally Posted by tiger View Post
    a competent machine shop can press in the bushing as long they know the orientation. This also means that the thrust arm must be off the car for them to do so. If ct can't do this job right, they are not likely going to install it right either.
  1. Need Thrust Arm Bushing Plasitc Inserts
    Last Post: 10-30-2005, 08:10 PM
  2. thrust arm bushing gone under 10k miles..........
    Last Post: 08-14-2005, 08:17 PM
  3. Thrust arm bushing question
    By pmulry in forum 5 Series BMW
    Last Post: 03-25-2005, 01:47 PM
  4. Thrust arms bushing Inserts
    By Bruno in forum 5 Series BMW
    Last Post: 03-01-2005, 05:25 PM
  5. Thrust Arm Bushing tool
    By ranger2002 in forum 5 Series BMW
    Last Post: 03-11-2004, 09:37 PM
