Results 1 to 10 of 10
Thread: Fuel rail pressure?
    Default Fuel rail pressure?
    Getting ready to pull the intake again to replace the front gasket. When I removed the fuel hose there was no pressure, was full of fuel but no pressure. Regulator on the other side of the rail?
    HUGE front gasket leak, 4 air bugles sitting at the back of the intake... man stuff is going on here.
    Aug 2008
    Jeff... it's the feds
    baton rouge, loserana
    the early intakes seem to **** the air ducts down into the plenum, i can't remember if that thing runs 3 or 3.5 bar but it should have at least a little residual pressure if run recently, i generally find the v8s blow gas all over the place like no other bmw when you crack a line. i thought about you the other day when i was doing the intake connectors on a 850ci and wondered if yours had shriveled up yet
    3 bar at the M70 engine, 3.5 bar at the M60 engine.
    I suspect the check valve is the problem.
    http://www.bimmernut.com/forum/showt...=fuel+pressure
    Thanks for the link, probably check valve then. I'll worry about it if I get hard starting issues.
    Quote Originally Posted by winfred View Post
    Yeah, last time I did this 2 were rolling around. One actually fell out when I took the rear plate off. PCV plate, those things just a passage from the intake to the crank? Mine flows freely both ways which surprised me. The valve itself functions if you put vacuum to the little port on the bottom outside. Didn't spend any time researching it since I had no electricity and put it together in the dark (Challenging indeed!). Seems to run stronger and didnt even hunt for isle or throw a code, new world order I guess.
    850? Intake connectors? WTF is that? I have check engine light on and cant read codes with the stomp test and would like to fix that error so I can sell the thing soon. Still want to replace the thrust/control arms since they are paid for and laying around. Dont want to sell junk on Ebay like everyone else.
    these things are rubber coated aluminum pieces that bolt to the head and the intake bolts to them, two per side, round a bill a pop, theres a couple rubber lines that crack up too that go from the two vent solenoids by the right distributor cap to below each throttle body, you can use 1/4" id vacuum line for those or fuel line. i always found it amusing that the can of lubromoly vacuum leak detector spray had a image of a m70 on it, but i don't think they make it any more because i can't find a pic in the current product line
    these http://bmwe32.masscom.net/sean750/V1...le/Image85.jpg
    count with a full day
    http://bmwe32.masscom.net/sean750/V1...ughIdleFix.htm
    No need to replace them when they have cracks. Cost you about $500. So far we have fixed them all with liquid gasket, and that is really no problem.
    Again excellent info!
  1. Custom fuel rail is done!
    Last Post: 02-10-2008, 09:59 PM
  2. Replies: 3
    Last Post: 10-06-2007, 08:32 PM
  3. HELP! can't get fuel pressure regulator out of fuel rail....
    Last Post: 01-21-2007, 09:26 PM
  4. Fuel line to fuel rail, pipe bursts
    By Mozarts_Ghost in forum 5 Series BMW
    Last Post: 04-14-2006, 12:52 AM
  5. Fuel rail and injectors
    By jj7 in forum 5 Series BMW
    Last Post: 04-04-2005, 08:40 PM
