Results 1 to 5 of 5
Thread: Direct Fit? 3.46 LSD on ebay
    Jul 2007
    Youngstown OH
    Default Direct Fit? 3.46 LSD on ebay
    The 3.46 LSD is from an e34 520, which i believe had an m50, so this should be a medium case. Can anyone help me on whether or not i will need to change the drive flange (part that connects to driveshaft). And also will this directly bolt in or will I need to swap my cover from my current rearend? Thanks
    http://cgi.ebay.com/ebaymotors/BMW-E...item20adc0f1c8
    Tickin' Red Bomb
    Jan 2008
    Phoenix
    Quote Originally Posted by bimmerred535i View Post
    I'm pretty sure you will have to change the drive flange and it would not surprise me if the drive axles dont bolt up either. The rear cover looks completely different also. I think I would keep an eye out for a LSD for your car as I see them pretty often.
    Johan
    Sep 2007
    Seattle, WA
    That's a small case diff from the 4 cylinder 520 (M40 I think). Would avoid it if you want a bolt-in swap. Also not sure how it'd hold up to the torque of your M30.
    Mar 2007
    Liverpool UK
    Agreed - The Whiskychaser and I did a direct swap with my diff from an e32 735i so that's an option for you depending on your reasons for the swap It was a piece of cake, all flanges matched perfectly. Otherwise you will want a donor from either a 525i (which will have a higher 'numerical' ratio) or a 535i...
    1995 XJR: 4.0L S/charged straight 6 Auto
    What... It's not broken??? I can still fix it
    Jul 2007
    Youngstown OH
    Quote Originally Posted by e34.535i.sport View Post
    Thanks this sounds like my route to getting my car running as I have blown the drive flange bearing in my open diff.
    Tickin' Red Bomb
  1. alternators and starters direct
    Last Post: 08-22-2009, 08:18 PM
  2. Cheap Wheels - Chrome on eBay - Discount Tire Direct
    By mholbrook in forum 5 Series BMW
    Last Post: 05-21-2006, 02:53 PM
  3. can someone please direct me to the best e46 site?
    Last Post: 10-09-2005, 02:07 AM
  4. Replies: 4
    Last Post: 08-04-2004, 09:03 AM
  5. why can't I fit E39 alloys direct to my E34?
    By mmaddock in forum 5 Series BMW
    Last Post: 05-26-2004, 12:26 PM
