Results 1 to 10 of 10
Thread: Funky fuel guage
    Default Funky fuel guage
    I know there was a thread on this but I can't find it because I am lazy. what did you guys do, clean the pickup or was it in the dash? I hate this fly by wire guessing how many miles to empty and will fix whatever if I know where to aim my technologies LOL.
    Thanks in advance.
    East Brunswick, New Jersey
    I was lazy too. Both of my e34's had the same symptom. I picked up two fuel pump assemblies for $50 each to replace the old ones. That did the job.
    '01 540it, 6/01
    '03 325i 5 speed, 9/02
    '10 535ix. 9/09
    '10 mini 6 speed
    '15 mini countryman 6 speed
    Sep 2007
    Seattle, WA
    This the thread you were thinking of? http://www.bimmernut.com/forum/showthread.php?t=41748
    I still haven't properly diagnosed it. Started to pull the sender out of the tank to give it a look see & cleaning but figured I should get new gaskets before I do that and had to order a set. Haven't had a chance to give it another go yet.
    Apr 2008
    Illinois
    Quote Originally Posted by yaofeng View Post
    I'd rather go with cleaning the fuel sender first, start with the easy one. My guess the fuel sender unit is sending intermittent signals to the OBC which is why it is displaying (accurate/close to accurate) reading.
    I think I'll start with jiggling the connection first and hope that helps. Looks easier than the dash too.
    Jun 2005
    Cheshire, UK
    Hey, Jeff!!
    Poke a stick down the filler hole. If it comes out wet, you have gas. Dry and you are running on fumes.
    If you want to get really technical you can even mark the stick with E - 1/4 - 1/3.. I know you never full it up further than a few bucks so any greater graduations are irrelevant.
    Laterz..........
    1997 e39 523SEi touring.
    Jan 2008
    Sweden
    When I fixed mine I found that I had to change the sender, wiggle the connector @ the pump/sender unit after reinstalling and make sure that the wiring behind the dash was properly inserted to get it to work 100%!
    Dec 2005
    Milwaukee
    I had been having problems with my fuel gage and ended up taking out the pickup assembly to have a look. Didn't see anything obvious and the float seemed to be free and the guide wire appeared varnish free. When I put it all back together the gage worked fine for one week. Then no fuel gage again.
    Frustrated one morning I got out and just wapped hard on top of the sender assembly and when I got back in the car the gage was working again.
    That night I took the connector off of the assembly, used a small pick file and cleaned out the female connectors on the plug and sprayed contact cleaner and file on the male prongs. Since then, approx two months the gage has performed flawlessly. Hopefully the same will work for you.
    94 E34 525i M50, Manual, 200,000 Miles
    02 E39 530i M54, Auto, 85,000 Miles
    I'm into this one! +1
    Quote Originally Posted by GoldenEagleFan View Post
  1. Fuel Guage Issue
    Last Post: 07-24-2009, 10:44 PM
  2. Fuel guage question.
    By Cavs in forum 5 Series BMW
    Last Post: 08-18-2006, 08:37 AM
  3. Fuel Sender/Guage issues
    Last Post: 06-11-2006, 12:46 PM
  4. Erratic fuel guage behavior at 1/4 tankfull.
    By pundit in forum 5 Series BMW
    Last Post: 01-06-2005, 07:49 PM
  5. air/fuel guage
    Last Post: 10-18-2004, 10:27 PM
