Originally Posted by
Tiger
For right now, I'd get steering locks and put them on the car. Tomorrow, I would take the car to the car stereo shop and have them install aftermarket alarm system. Since they have the key, you have to tell the guys the situation and make the overide button very difficult to find. Only the CRV.
An alarm is absolutely worthless.
What you should do though is get a cutoff switch installed somewhere. Have it cut power to the fuel pump. That way it'll crank over but not start. That'll usually just frustrate most thieves (how often does a car cranking but not starting frustrate us and we're not even trying to steal our cars!) and they'll give up after cranking it for a while with it not starting. Do not install a cutoff switch on the starter. Yes, it will do the same thing. But it will be a bit more obvious that there's a cutoff switch installed somewhere if it won't crank and they might try and find it.
