So once again,
Car starts up fine, let it idle for a little bit idles at 750 or so rpms. Once It gets out of the blue on the temp gauge and then the idle drops down to 350 ad the car starts to shake.
Here's what I think:
-If coils are the culprit, wouldn't it act funky from the get go.(I haven't pulled them yet so they could still be a possibilty but I doubt it.)
- Car is throwing a code for bad Maf, I'll replace it but I don't think that's what's causing this either, because the symptoms exhibited don't sound like a bad Maf, Or could it?
-o2's are out of the question, Let's just say the Kitty's weren't implemented when I had the "House" built.
This problem started after I swapped out battery's but I don't think that could be the cause of the problem.
TIA
-Dan
