Results 1 to 7 of 7
Thread: hub centric rings
    Jan 2005
    Melbourne Australia
    Default hub centric rings
    Had a not quite great experience, still lucky
    got a flat - was assisted in the changeover by one of the work fitters, the hub centric ring was left on the hub and the spare (which does not require the ring) was pressed on and tightened. a short drive later, with vibration, pulled over. jacked up the car again, loosened the studs wiggled the wheel and re-tightened. i did not remove the wheel which i know as a mistake now. This did not fix the vibration.
    when i got the flat re-tyred (could not be repaired) and put back on they noticed the remains of the hub centric ring. the remains of the ring was not re-useable and they said i was lucky not to snap wheel studs and loose the wheel.
    Got a price for replacement ring $125 and only as a set of 4. measured it up myself, found it was the exact dimentions of s/s 3" tube. 67mm od 1.6mm wall. 5 min later and an 11mm 'egg ring' fitted.
    Sometimes things just work. ;-)
    1994 540i Auto
    live fast; die sideways
    13.3 @ 104mph (not in the 540)
    15.4 @ 150 Kph in the 540 (24/9/07)
    Sep 2008
    Gold Coast, Australia
    Those s/s ones would last longer to and be stronger then the alloy ones.
    Evanston, IL
    Default That is a ridiculous price for those!!!!
    I have them as well on my summer 16" wheels but have never paid more than $20.00 for a set of four and even then thought it was too much. $125.00 is an outrageous price for even ss ones. I used plastic or metal ones. Let me know if you want a cheaper source of these rings.
    model A670 at tirerack.com... should be all over ebay too.
    Jan 2005
    Melbourne Australia
    the $120 was for alloy, not ss. i used s/s because 3" tube was a coincidental exact match for size :-)
    1994 540i Auto
    I prefer the plastic ones, seems the tire rack ones fit loosely on anything I have aftermarket here.
    Sep 2004
    romania
    no way u can snap studs and loose the wheel, even with no rings. they only center the wheel. anyway i think ss is the best ,shold last forever
  1. I think e38 wheels need hub centric rings
    By 94_e34_525i in forum 5 Series BMW
    Last Post: 10-18-2007, 08:42 PM
  2. Hub centric rings?
    By karl1171 in forum 5 Series BMW
    Last Post: 02-27-2007, 05:20 AM
  3. hub centric rings, what are they?
    By guinness in forum 5 Series BMW
    Last Post: 07-06-2006, 06:37 PM
  4. Plastic Hub-Centric Rings??
    By E34 530 in forum 5 Series BMW
    Last Post: 03-01-2006, 05:04 PM
  5. Hub centric rings
    Last Post: 11-03-2005, 08:44 PM
