Originally Posted by
Ross
Pretty sure your M50 should have a3.5 bar fuel pressure reg., it's marked on it. 45 psi is too low if so.
Your other indications are the pressure bleeding down and apparent rich running, also things attributable to a FPR.
Check pump pressure to be sure it is capable of more, a good one will be ~70 PSI at the outlet. The bleeding down points at the regulator though.
Low pressure results in crappy atomization from the injector causing your sooty plugs.
Before throwing your wallet at a bunch of sensors that you've ostensibly tested and believe good I'd be swapping in a fresh FPR.
