Results 1 to 8 of 8
Thread: oil pump
    Jun 2008
    south africa
    Default oil pump
    i would like to know can the oil pump stop working i mean stop pumping the oil
    does the oil light stay on even if the engine is running.
    just would like to know
    East Brunswick, New Jersey
    If the oil pump stops working the engine will be damaged in a short time. There will be no oil pressure to delive oil to all parts of the engine needed for lubrication. The oil pressure switch will trigger the oil light to come on. You will hear loud clatter on the valves.
    '01 540it, 6/01
    '03 325i 5 speed, 9/02
    '10 535ix. 9/09
    '10 mini 6 speed
    '15 mini countryman 6 speed
    Jun 2008
    south africa
    Quote Originally Posted by yaofeng View Post
    so if the oil pump stops working will the oil light will stay on even if the engine is runing ?
    thank you
    Nov 2006
    Mid-Atlantic, USA
    You're asking some odd questions. The oil-pressure warning lamp (idiot light) will stay on anytime there is insufficient oil pressure in the system and the key is on. A more common BMW failure is the oil-pressure-light sending unit itself, which is readily available, easy to replace, and usually costs less than ten-bucks. If I could understand what you're talking about I'd probably suggest starting there, first.
    Oldham, England
    Quote Originally Posted by allerston View Post
    thank you
    Yes. Its the engine's way of telling you ' I dont have any oil pressure'. As the sensor and light system isnt very accurate, it could also be the engine's way of telling you ' I didnt have any oil pressure and I'm totally fkd now'. What prompts the question?
    Jun 2008
    south africa
    [QUOTE=BMWCCA1;328380]You're asking some odd questions. The oil-pressure warning lamp (idiot light) will stay on anytime there is insufficient oil pressure in the system and the key is on. A more common BMW failure is the oil-pressure-light sending unit itself, which is readily available, easy to replace, and usually costs less than ten-bucks. If I could understand what you're talking about I'd probably suggest starting there, first.[/QUOTE
    that is all very interesting
    thanx.
    Reading, UK
    The M50 engine is also extremely prone to the pump running dry when you powerslide the arse end of the car in one direction because of the shape of the sump.
    If you intentionally boot it on a gravel carpark and hook it hard around, you'll get a *bong* Oil Press warning flashing in your display.
    Nov 2004
    Split, Croatia
    Quote Originally Posted by Ferret View Post
    I powerslide (and hard) quite often and never got the Oil Pressure warning?
    Had two M50B25 engines in my car, now I'm on M52B28 with M50 intake and sump - same thing.
  1. New m20 oil pump.
    Last Post: 11-21-2009, 11:57 PM
  2. oil pump
    By allerston in forum 5 Series BMW
    Last Post: 10-28-2009, 04:37 PM
  3. Fuel pump gone; Opel pump fit in BMW?
    Last Post: 09-27-2009, 08:51 PM
  4. Anyone have p/s pump for a '92 M50 525?
    Last Post: 08-04-2008, 11:56 AM
  5. E36 oil pump vs E34 oil pump M50
    Last Post: 02-20-2008, 11:16 AM
