Results 1 to 10 of 12
Thread: tail lights question
    Default tail lights question
    Dashboard error indicator says license plate lights are not working, but in fact they are.
    Now, backup lights quit working, both sides. Dashboard indicator does not show this.
    LKM problem? Fuses? Coincidental failure of BOTH backup lights?
    Fix?
    Default A common problem is the wiring on the trunk hinge sometimes breaks/shorts out
    Quote Originally Posted by Dash01
    Fix?
    Mar 2004
    So Cal
    GAM is correct. Check the wires going through the left side hinge of trunk. There's a hard plastic cover that digs into the wires which causes problems.
    Greg Mendoza
    Many thanks!
    Would this explain 1.) the faulty inop. license plate indication at the dashboard AND; 2.) the backup lights are not working, but no such indication shown at the dashboard?
    Apr 2007
    Hi all,
    I just had the same problem! I had a warning in the dash CCM about the license plate lights, but my back-up lights were not working. The licence plate lights were working but they were faded, also the inside trunk lights were not working.
    The wiring to the trunk was in bad shape because of the black plastic protector. The brown wire for the ground was cut in two. Fixed it and all works fine now.
    Those archives are great.
    1993 (build 93/05) 525i automatic M50TU (vanos) 263K miles (ca. 423000 km) in Montreal, Canada (bought the car 9 years ago in San Diego, CA)
    Jul 2004
    Quote Originally Posted by alex 1993 525i auto View Post
    Hi all,
    Thank you for posting. Glad the problem was solved. Would you please post a picture of the "black plastic protector" for location awareness, if this is possible.
    deleted air conditioning
    Back in 2012 I posted wire loom info and broken wire looms http://www.bimmerboard.com/forums/posts/1084323
    By black plastic protector he probably means the black plastic on the trunk lid brackets where the wire loom goes thru
    http://i19.photobucket.com/albums/b1...Y/DSC03246.jpg
    Quote Originally Posted by Rustam View Post
    This was a post from 2005, doubt they will reply. Shoguns reply should help.
    Jul 2004
    The post before mine came yesterday.
    Apr 2007
    Yes, the black plastic piece was this one:
    51491973695
    Part no. 9 in the RealOEM diagram:
  1. Tail lights
    Last Post: 05-03-2010, 05:01 AM
  2. Looking for tail lights
    By bmw_525i in forum 5 Series BMW
    Last Post: 10-03-2008, 06:05 PM
  3. LED Tail lights?
    By GJPinAU in forum 3 Series BMW
    Last Post: 09-09-2008, 12:13 AM
  4. e34 sedan tail lights vs e34 touring tail lights
    By bad_manners_god in forum 5 Series BMW
    Last Post: 02-10-2008, 08:31 PM
  5. Tail lights, Interior lights, 1 license plate light not working
    By Another Bama Fan in forum 5 Series BMW
    Last Post: 10-28-2006, 05:53 PM
