Results 1 to 5 of 5
Thread: '87 535i question
    Default '87 535i question
    My brother has an '87 535i with water and fuel in the exhaust. No indication of oil contamination such as milky color, etc, but rather just water and unburned fuel in the exhaust.
    Other than a bad headgasket, what might cause this?
    Dash01
    '90 535ia 272K miles
    Cracked head.... but most likely the gasket.
    Sep 2007
    Michigan
    Put some dye in the radiator, the kind that shows green with a black light and see if water is getting through from the cooling system.
    Houston, Tx
    How much water are we talking about here? It could just be the catalytic converter doing it's job and your engine running excessively rich.
    I've got an 87 535 as well, and that's all mine turned out to be. A few of the plugs were a little wet with fuel but then again, my M30 was in desparate need of a valve adjustment as well. There's a few writeups on mye28.com's forums about how to do that.
    "Scarlet" `97 540/6 with sleepy mods.
    "Box Car" '87 535isA - Old School Charm, new school Flair
    in case there is no loss of coolant, why should he worry? I assume he only drives short distances, the answer to that see comments of Snakeeyes.
    Let him drive a longer distance that the cat gets really hot/to operating temperature. Short distances even allow fuel to enter the oil.
    Experts believe that one start is equivalent to 500 miles of normal driving. Danger of oil dilution.
  1. 535i exhaust question
    Last Post: 05-28-2009, 09:20 PM
  2. HG replacement question ('90 535i)
    Last Post: 08-10-2006, 11:31 AM
  3. 535i A/C Compressor question
    By Newbie535i in forum 5 Series BMW
    Last Post: 07-31-2006, 09:46 PM
  4. Re-keying question - 92 535i
    By Bill in MA in forum 5 Series BMW
    Last Post: 03-24-2005, 08:01 AM
  5. Coil question - 92 535i
    Last Post: 06-21-2004, 08:12 PM
