Have had some minor powerlosses @ speed and wanted to change the sparkplugs on my M60.. I opened up and found a scary amount of oil in and around the plugs![]()
Could it be the no. 15 and 16 gaskets as seen here: http://bmwfans.info/parts/catalog/E3...er_head_cover/
Or should I look elsewhere for the leak?
Do you mean no. 7, 8 and 9 @ http://bmwfans.info/parts/catalog/E3...er_head_cover/
Primarily just #9 Rubber Seal(on my M60 there are 22) should be replaced as they tend to break from the heat if very old but of course you really can not always know that you will not find other needs as you do the job.. bolts as far as I know are normally reusable but as they are inexpensive maybe its wise to have them on hand..
1995 540i Manual build 1/95
Guys youŽre gold! Thx a lot!![]()
Maybe its obvious but you'd benefit from at l;east one other pair of hands when trying to replace the covers.. you know , Gravity and all.. or are you already done? I bet Regal would say replacing the Coil Boots is excessive too.. it was suggested to me that Oil weakens Rubber which could result in some spark arcing out thru compromised boots.. I went ahead with it for the modest cost..
Thx for the pointers Jehu, and no I havenŽt begun yet but IŽll be sure to check all the boots as they are indeed soaked in oil!
