Results 1 to 7 of 7
Thread: A/C prob. - Seeking hint
    Apr 2005
    Canada
    Default A/C prob. - Seeking hint
    Here are the facts:
    1) no cooling air at all (the problem) whatever is the A/C temp setting.
    2) system have been converted to R-134 2 years ago at that time condensor and receiver/dryer have been also change as well as the the compressor oil.
    3) compressor cluch operate well when A/C button is activate and compressor seems to run fine (no special noise / no apparent oil leak)
    4) the slow speed resistor on the électric fan un front of the condensor have been bypass so when A/C is activated this fan also run max speed
    Any clue / hint / what to check
    Sounds like low refrigerant level. Check pressure... it needs to be around 27 to 30 PSI when the compressor is running. I think it needs 50PSI static to trigger compressor to run.
    Apr 2005
    Canada
    But the compressor run right away after i push the A/C On/Off button so the pressure should be OK ! But instead of cycling like before the compressor now runs continuously without giving any cool air. I always thought that without the minimum refrigerant level the system inside pressure will be too low and a pressure switch will prevent the compressor clutch to operate so to protect the compressor itself.
    Mar 2004
    Quote Originally Posted by Claude View Post
    Can you pop some gauges on there to see what is going on? Would help a lot.
    Scott
    07 525i 22K, 07 328xi (41K)
    Feb 2007
    GreenHills East-Philippines
    +1 if your refrigerant is low but not low enough to not let the compressor work you'll still have insufficient cooling. Put a gauge on it. It can also mean your compressor is not pumping right that you might need to replace it even if visual check is ok and no funny sound can be heard.
    HID 5000k low 3000k fogs
    dynaudio seps. mc intosh amp
    Race logic TractionControl
    We need pressure reading.
    Probably low refrigerant but heater valves stuck open would warm the chilled air.
  1. Update on M30 no start. Hint..Does anybody like MSD?
    By Felixdacat in forum 5 Series BMW
    Last Post: 10-19-2006, 03:29 PM
  2. Question on fuel pump (Shogun hint hint)
    By BillionPa in forum 5 Series BMW
    Last Post: 09-08-2006, 07:11 AM
  3. Seeking help: Air Conditioner issue
    By nyc525iTe34 in forum 5 Series BMW
    Last Post: 05-08-2006, 09:48 AM
  4. Helpful hint for Microfilter change
    By Picatavi in forum 5 Series BMW
    Last Post: 02-16-2006, 04:25 PM
  5. Desperately seeking Carfax
    Last Post: 04-01-2005, 04:09 PM
