Results 1 to 4 of 4
Thread: battery draw found but which module is this...
    O.C.
    Default battery draw found but which module is this...
    So I have a battery draw 0f .500 amp, half an amp. Found some relays were causing the draw and I believe the body control module(controls windows and elec. locks, sun roof, etc)... removing a fuse(30amp,brown) in the rear seat junc. box nearest the module brings my draw to .19 milli amps.
    Would anyone like to share, or have info on this module. rear seat junc. box info?? I need fuse location numbers, etc.
    Thank you.
    BTW no cash for my M30!!!
    Dunlap Illinois
    Isn't the fuse layout label underneath the cover?
    I have the rear box removed from a '94, probably all or most of the modules, the marked lid and a Bentley.
    The fuses outboard of the box can be unclipped easily, some cars I've worked on had them mixed up.
    Let me know what you need.
  1. Battery Draw test for 89 535I
    By aston_jag_tech in forum 5 Series BMW
    Last Post: 04-10-2008, 07:00 AM
  2. Battery Killer Found !!!
    By Happy_Go_Lucky in forum 5 Series BMW
    Last Post: 09-25-2006, 10:06 PM
  3. Replies: 24
    Last Post: 08-30-2005, 10:33 AM
  4. remove ignition key - battery draw w/engine off
    Last Post: 09-29-2004, 10:42 PM
  5. FYI: Found replacement battery for $40 CDN
    By talltorontoguy in forum 5 Series BMW
    Last Post: 03-22-2004, 03:14 PM
