Tiger, you must be right about it working halfway. Tuesday was 98 degrees and it stayed on normal, even at the traffic lights. I guess it only spins down to a stop in the garage.
I did notice something strange when I replaced it though...the picture in Bentley and on realoem show the fan blades installed between the clutch and the engine. I noticed that the blades were in front of the clutch when I removed it and thought the mechanic who changed the fan had installed it wrong. But when I put the new blades behind the clutch, I found that the fan hit both the brake vacuum lines and the intake duct. When I put the blades on the front of the clutch, it still did. I pulled the vacuum lines out of their channels and zip tied them to pull them back, and loosened the bolts on the air filter housing and moved it back as far as it would go. The fan still hit the duct but after seven hours of messing with it I said to hell with it and went to sleep for the three remaining hours before I had to get ready for work. It settled in by the time I got to work (11 miles down I40, usually at 80-90mph).
Tonight I had time to raise the hood and check to make sure it was completely clearing the duct and I see coolant all over the engine compartment. Although I had not noticed it, it was also hitting the top left radiator hose and had worn a pinhole through that. The fan blade came from Bell BMW and I checked and Autohaus sent the correct Sachs clutch (2100 010 032). What gives? Which side does it really go on and why is it hitting other components if installed as pictured? Since Bentley covers all 4 engines, I assumed it pictured something other than the M60, but when I saw the drawing on realoem for the 540, I have to wonder. It barely clears the air duct with the blades installed in front of the clutch.
The stone age didn't end for a lack of stones. Neither will the hydrocarbon age......
