Results 11 to 20 of 26
Thread: Fuel gauge issues
    Aug 2008
    Quote Originally Posted by aston_jag_tech View Post
    go to a salvage yeard, take out a fuel pump sender assembly, check the resistance of the sender yourself and if ok, install that bad boy in your car
    Quote Originally Posted by yaofeng View Post
    My vote is the fuel level sender. Happened on both of my e34's. Fixed by one from ebay.
    I don't understand how you guys conclude this - if the obc gets an accurate reading then how can the sender be faulty?
    how do I check the OBC for fuel content?
    Quote Originally Posted by tim eh? View Post
    Sep 2007
    Seattle, WA
    My friend is using the range function along with the knowledge that she averages 20mpg.
    Which is why I don't see how it could be the sender if the OBC is getting a signal saying it's not empty when the gauge says it's empty.
    Although I'm kind of recalling that she says it's either saying it's got a half tank or is empty. Maybe the sender is going wonky and is giving enough of a signal to the OBC for it to think it's half full while the cluster is getting a worse signal that says it's empty?
    Should try to just pull my sender out of my M-Sport and slap it in her Touring...
    Aug 2008
    I know there are 2 types of pumps, is the level sender the same?
    test #6 and #7 with unlocked OBC (#6 is immediate, the other is approximated... i think)
    edit *- mine reads in litres (i think)
    my range option says almost exactly what the OBC says according to my calculations and the guage that no longer works. Sounds like the sending unit is fubared in some way now.
    Quote Originally Posted by bubba966 View Post
    Jan 2008
    Sweden
    Well I swapped mine for one from the salvage yard, seems slightly less erratic but still drops to empty about 50% of the time compared to the old where it was 85%..
    My next move is to try the fully working sender from my 525 and to see whether I still get erratic behavior.
    IŽll keep you posted (œ tank so I gotta use most of that first! )
    Jan 2007
    Dayton Ohio
    yes it helps to clean the wires. I use a cotton ball and contact cleaner
    pumps on top, fuel level shouldnt matter?
    Quote Originally Posted by Bo525i View Post
    Jan 2008
    Sweden
    You still have to stick your hands into the gas to release the pump/sender unit from the base.. So IŽll wait!
  10. #20
    Jan 2008
    Sweden
    So, finally got around to changing fuel pump and the sender units, not from my 525 as the pump differs but from a 95 540 @ the salvage yard.. Now the gauge works like it should and as a bonus the obc now reads below 8 liters on obc code 7, got a reading of 4.4 liters after installing the new units (not on code 6 tho, that still reads 8 liters) Never had it do that before!
    Another thing that I found was that my old pump wasnŽt seated properly lacking about œ inch on the right side looking into the tank, so be thorough and seat it really well by pushing a bit hard when you have to reinstall the pump!
  1. gauge cluster issues
    By h2oyo in forum 3 Series BMW
    Last Post: 04-12-2009, 10:53 PM
  2. fuel gauge
    By julian1966 in forum 5 Series BMW
    Last Post: 02-01-2008, 04:19 PM
  3. Replies: 16
    Last Post: 01-25-2008, 02:47 PM
  4. Oh boy, wait till you read these gauge issues!!
    By henryw525i in forum 5 Series BMW
    Last Post: 03-24-2007, 02:31 AM
  5. Fuel Gauge inaccurate, but fun!
    By Been-Jammin in forum 5 Series BMW
    Last Post: 08-28-2005, 06:58 PM
