Could have sworn I saw a response to this a minute ago!!![]()
Anyway, to clarify I can get the ashtray out easily enough. There is a 'silver' metal tab underneath the moving carriage but pushing it up/down doesnt release it.
My cigar lighter has never worked. There is a hole in the bottom of the socket where a wire should be for a start! No problem except I'd like to be able to charge my mobile phone. I've seen a post about attacking this by removing the radio. But the heating controls are still in the way and under them is a plastic panel anyway. So how do you get the sliding cassette out?
I have always removed the console. It really depends on where the wires are that run to the lighter. You can remove the radio but you have to know which wire(s) you are looking for, and you have to have small hands. I am guessing you have pulled the ash tray and can see anything through the hole in the back?
Here is a pic of the connector
If you pull this panel
some time you can reach the connector using a three finger through the hole behind the ash tray. But most times you have to remove the lower center console.
Push down gently on the cigar lighter part and pull the ashtray towards you. To reinstall lift up on the cigar light part and gently push the tray back in. It takes a little practice
hey that circuit's always live not that you didn't know that already.
Update:
Pressing down on the lighter resulted in a worrying 'crack!' noise. But it seemed to go back in place by pushing upwards again. Wiggling the 'drawer' side to side got it out in the end.
There is a hole in the back of the housing on the right side where the wires would exit. I say 'would' because I cant see anyThe centre console sweeps round to meet the steering column so I've either got to remove that or search from above via the radio aperture. To make it worse, it looks like the metal cig lighter tube is moulded in. What a PITA. I think my options are
1. Go to dentists' suppliers, buy a mirror on a stick and persevere
2. Say WTF. Just make sure my phone is charged like I normally do
PS. One bit of good news - the ashtray light works! Admittedly its not much use as there is no clear section for it to shine through
"Push down gently on the cigar lighter part"
Have you never taken out the center lower console? I owned my Bimmer 2 years now and have had the console out at least 5 or 6 times now. Not that much trouble but the plastic can be brittle so take your time.
