Results 1 to 4 of 4
Thread: MAF Wiring/Numbering
    St. Louis
    Default MAF Wiring/Numbering
    Searched, but could not find....
    My MAF appears to be inop (visual burn off test failed), so I need to check the voltage. I have a 4 pin connector. The wires are colored:
    Brown with Orange stripe
    Grey w/ Yellow Stripe
    Red w/ White Stripe
    Black
    Does anyone know which wire is associated with pin number as referenced in the Bentley manual.
    I need to test Pins 1 and 4 for burn-off voltage, and then pins 2 and 4 for voltage test.
    Thanks!
    L.
    1995 525iA 200,000 Miles
    You have them listed in numerical order, bn/oe is #1 etc. Pretty sure the connector is maked too.
    St. Louis
    Quote Originally Posted by Ross View Post
    Thanks for the quick response!!
    I looked more carefully at the connector, and you are correct! There are some very small numbers there to id the wires.
    I see in the Bentley manual that there are 6 wires on their connector. I have four. Do I still test wires 1 and 4?
    I am not getting any burn off voltage across 1 and 4 at his time.
    L.
    St. Louis
    Quote Originally Posted by Luftpost View Post
    L.
    Anybody with any advice on how to test the four pin connector?? Anybody....?
  1. Wiring
    By colamangr in forum 5 Series BMW
    Last Post: 04-04-2006, 12:50 PM
  2. amp wiring
    By xphilter in forum 5 Series BMW
    Last Post: 05-13-2005, 02:20 PM
  3. amp wiring 89 535
    By Dizzy in forum 5 Series BMW
    Last Post: 08-25-2004, 05:39 PM
  4. OT 740i cylinder numbering
    By Paul D in forum 5 Series BMW
    Last Post: 07-17-2004, 12:13 PM
  5. OT 740i cylinder numbering
    Last Post: 07-15-2004, 11:26 PM
