Thread: Ultimate Car Monitoring
    Apr 2008
    Belgium
    Default Ultimate Car Monitoring
    I'm planning to do that first for my M20. seems easier for the oil add-on
    1)oil pressure
    detect failure in oil pump
    2)oil temp
    to know when engine is ready to roar
    3)coolant temp
    on the top hose. will not detect a stuck closed tstat
    4)fuel pressure
    detect failing fuel pump
    5)trans fluid temp
    to know when trans is ready to perform
    stuff looks like that
    same idea for fuel pressure
    however I have seen on ebay a sensor for trans fluid temperature
    where would you put that?
    Oldham, England
    My carsoft says it will do that but doesnt. Fister's ADS kit does. But you need a laptop with a built in com port and 2 megs of memory to run it.
    New Mexico
    Where are you planning to locate the gauges?
    M20 525/7 Bore: 84.50mm Stroke 81mm CR 8.5:1, blue printed/dyno & custom chip. Boost @ 6.5psi ~246hp @ 5300rpm / torque @ 269ftlbs. @ 4250rpm
    Apr 2004
    Semi OT, my suburban has trans fluid temp sensor tapped in side of trans fluid pan. That, plus synthetic fluid, are to monitor heavy duty towing. With single horse trailer towing trans lasted 195k.
    Sep 2007
    Seattle, WA
    Quote Originally Posted by Gene in NC View Post
    I added a tranny fluid temp gauge when I replaced the tranny in my truck some time ago. Also installed a secondary fluid cooler & a secondary fluid filter (use high flow racing filter to minimize flow impedance). I put the temp sender in the secondary filter housing (it was drilled & tapped for another fitting or a sender) which was installed after the secondary fluid cooler.
    Fluid goes from tranny to primary in-rad cooler, out of primary cooler into secondary cooler, out of secondary cooler into secondary filter/temp sender, out of secondary filter/temp sender back to tranny.
    Ran it in that order so as to get a more consistent temp reading as it'll be reading a steady flow right after all of the cooling & filtering. Putting it in the pan would've put it right next to my exhaust, and I'm sure the tranny itself heats things up too. And I'm sure that the fluid in a deep tranny pan has hot & cold spots to some extent.
    Nice to know the tranny fluid temp so I know if I need to adjust how I'm driving or if I need to manually engage the torque converter lock-up (added that feature as well when I installed the new tranny).
    I installed factory tranny cooler on 2005 Acura MDX and it runs in the same manner as you spoke... I think it is from tranny to external cooler into raidator cooler and back to the tranny.
  1. Ultimate Garages
    By Tiger in forum 5 Series BMW
    Last Post: 08-05-2010, 11:59 AM
  2. BMW E34 Ultimate CD & Guide Ver. 1.0
    By cybereclipse in forum 5 Series BMW
    Last Post: 10-27-2007, 02:25 PM
  3. Replies: 12
    Last Post: 02-23-2006, 08:47 AM
  4. the ultimate chassis for the V12 M70
    Last Post: 10-22-2005, 02:29 PM
  5. Ultimate Wax Job
    Last Post: 08-09-2004, 07:06 PM
