Results 1 to 4 of 4
Thread: CEL Codes
    Tampa Bay, Florida, USA
    Default CEL Codes
    OK I got a CEL on and finally read the codes:
    0c, 0d - O2 sensors (theyve been on 100Kmiles)
    19 Ignition Coil 1 (oil on coil due to valve cover gaskets?)
    17 Ignnition Coil 6 (oil on coil due to valve cover gaskets?)
    10 Cranks Sensor bad connection; ground?
    Which do I attack first?
    Ramon
    Ramon
    1994 540iA Nikasil EAT Chip
    Tampa Bay, Florida USA
    check the oil situation in the plug holes and clean first, reboot the computer and wait for new codes.
    Thanks, Jeff
    Ramon
    Seriously the V8's will throw all kinds of codes for any one or multiple reasons. My take at cleaning the oil out (including inside the plug ends) is that is that shorting can cause a myriad of faults to be displayed. Once you know that is not the problem the resetting of the computer will tell you the next avenue of attack. I would venture intake leaks but I think I remember you posting that has been done already. If there is oil pooled the valve cover gaskets need to be done.
    Quote Originally Posted by MBXB View Post
    Thanks, Jeff
  1. BMW stomp test blink codes fault codes
    Last Post: 11-12-2009, 10:53 AM
  2. SRS Codes
    By Golgade in forum 5 Series BMW
    Last Post: 05-22-2009, 09:11 PM
  3. Reading Codes
    By KYSTYLEMOJO in forum 5 Series BMW
    Last Post: 07-18-2006, 06:54 PM
  4. OBC codes
    By rickm in forum Electronics & Lights plus A/C
    Last Post: 01-01-2005, 10:37 AM
  5. Trying to get engine codes
    By phildg2000 in forum 5 Series BMW
    Last Post: 07-14-2004, 08:46 AM
