Results 1 to 10 of 11
Thread: M50 cam "holder" tool - got one?
    Jul 2004
    Vancleave, MS
    Default M50 cam "holder" tool - got one?
    Hi, Thinking of repairing my noisy vanos with either the $250 job from Dr.Vanos.com...
    or the $20 parts for the total DIY job from Beisan Systems.
    So... anyone have the cam "hold it in place" tool for the cheap?
    Or a creative alternative? I don't have fabrication means... so it's gotta be simple.
    Cheers and thanks.
    Rob.
    Aug 2008
    Pennsylvania
    Its doable without one but it will take you some time getting the cams aligned correctly.
    Mar 2004
    Quote Originally Posted by RobPatt View Post
    Cheers and thanks.
    Rob.
    Just sold one on ebay for $50
    07 525i 22K, 07 328xi (41K)
    East Brunswick, New Jersey
    You can do it without the alignment tool. You can remove the camshafts without the camshaft removal tool also.
    '01 540it, 6/01
    '03 325i 5 speed, 9/02
    '10 535ix. 9/09
    '10 mini 6 speed
    '15 mini countryman 6 speed
    Get a straightedge/solid, straight piece of metal and lay it along the rear, square ends of the camshafts to align. I had to grind down a torx socket to fit one of the small head bolts at the timing chain cover, otherwise, all the other steps can be done without specialty tools. Oh, I used a safety pin to hold down the secondary chain tensioner.,
    We have plenty of pics of this if you need a hand later. Good luck with it,
    Dave
    On the vanos front, I've used the Besian Sytems kit for a friend's M52 and it worked very well. Worth the money.
    Dave
    Jul 2004
    Vancleave, MS
    Great, thanks Dave... finally getting ready to do this job... I think I'll get a few strips of alu from Lowes... about 1 inch wide and 1/16 thick... rivet together and trace the layout of the square end of the cam... then cut the alu and use it as a guide for keeping the cams in sync...
    What can I use for the crankshaft/flywheel locking pin... just a screwdriver ?
    Will do this in a month or so soon as I learn what tools I need and get another good weekend... Thx.. -Rob.
    Don't worry about trying to lock the crank. Just be sure to have things lined up properly when you piece it back together.
    Good luck and have fun,
    Dave
    San Joaquin Valley CA
    Hey Rob:
    you can borrow this one I made from square stock.
    Also if you want to lock the flywheel you need a Phillips screwdriver as the hole is only about 6mm or so...
    Link to my M50 engine rebuild thread
    http://www.bimmernut.com/forum/showthread.php/43339-M50-Eng-4L30E-Trans-RRR-Far-More-Than-I-Ever-Expected?highlight=93+525+paul
    I am doing the single Vanos repair on my E36 M3 with a Beisan kit, I bought this here for only $92
    BMW Vanos Valve Camshaft Alignment Locking Timing Tool - Samic Special Tools
    BMW Vanos Valve Camshaft Alignment Locking Timing Tool - Product Description- •BMW Single Vanos Valve Timing Kit Special Engine Tools
    •Include: CAMSHAFT LOCKING FIXTURE for 4 & 6 CYLINDERS
    • 1) CAMSHAFT LOCATING FIXTURE
    • Aligns and holds the camshaft in position when assembling cylinder head and replacing timing chain.
    • Engines: M42, M44, M50, M52, M52TU, M54, M56, S50US, S52US.
    • 2) TOP DEAD CENTER PIN:
    • Use to lock the flywheel at Top Dead Center when removing
    • or replacing the camshafts or VANOS assemblies.
    • Engines: M42, M43, M44, M50, M52, M52TU, M54, M56, M60, M62,
    • M70, M73, S50B30, S50B32, S54, S62.
    • 3) VANOS TURNING WRENCH:
    • Use to adjust VANOS position on single VANOS engines when removing or installing.
    • Engines: M50, M52, S50US, S52US.
    • 4) CHAIN TENSIONER LOCK PIN:
    • Locks chain tensioner during timing.
    • Engines: M50, M52.
  1. Peake Tool - Will it tell more than just "1221" ??
    By Super90 in forum 5 Series BMW
    Last Post: 04-11-2007, 01:37 PM
  2. Replies: 11
    Last Post: 08-29-2006, 08:06 AM
  3. article on the "world's greatest tool"
    Last Post: 03-23-2006, 06:56 PM
  4. AutoZone "Loan a Tool" Program...Of course, it's FREE !!!
    By CheapCheap1 in forum 5 Series BMW
    Last Post: 07-30-2005, 04:51 AM
