Results 1 to 9 of 9
Thread: Mystery coolant leak 530
    Default Mystery coolant leak 530
    Driving around no probs, stopped and came back to the car while it was shut off, trail of cool blue. Opened the hood, leaks in the heater valve area from underneath but couldnt see any leaks under hood so I drove it home and on ramps. nothing. level is lower but nothing major. All new hoses and re-tightened most incase. I will tighten the other ones that are almost impossible to get to but still, no signs of leakage.
    An clues?
    Aug 2008
    Pennsylvania
    Check the U hose that goes from the aux water pump to the heater valves. Mine likes to leak in the winter and its hard to tell that it leaks. Stick your hand under the pump and see if its wet. Another leak I had was the hoses that go into the firewall. They leaked at the heater valves, and as you know those aren't easily seen from under the car or above it.
    Aug 2008
    London, UK
    Could it be leaking from inside the cabin under the dash, and dripping out down the heater pipe into the engine bay ?
    no everything was dry. Tightened all clamps at the back end of the motor and went for a test run...nothing. Must have healed itself.
    Quote Originally Posted by sal_park View Post
    the twisty hose is also dry, moved it around to check for a leak.
    Feb 2007
    GreenHills East-Philippines
    [QUOTE=632 Regal;326095]the twisty hose is also dry, moved it around to check for a leak.[/QUOTE ]
    can you hear a hisss when engine is off and is hot ?
    HID 5000k low 3000k fogs
    dynaudio seps. mc intosh amp
    Race logic TractionControl
    only the skin from my hand.
    Quote Originally Posted by bmwrp8 View Post
    Aug 2008
    Pennsylvania
    Sounds like you just tightened the hose clamps up and it sealed the leak.
    Tampa Bay, Florida, USA
    Same **** happened to me last year. Bought a used aux pump nad valve from dennyg.
    Ramon
    1994 540iA Nikasil EAT Chip
    Tampa Bay, Florida USA
  1. Follow-up on my M50 oil leak & coolant leak
    By Dick Schneiders in forum 5 Series BMW
    Last Post: 03-06-2008, 10:51 AM
  2. coolant leak help!!
    By gamjohn2 in forum 5 Series BMW
    Last Post: 05-06-2007, 11:48 PM
  3. Got a mystery coolant loss on the m60.
    By yy101 in forum 5 Series BMW
    Last Post: 12-18-2006, 10:22 PM
  4. The Mystery of the Disappearing Coolant
    By 92E34 in forum 5 Series BMW
    Last Post: 10-23-2006, 02:30 PM
  5. mystery fluid leak, sickly sweet smell.......?
    By chris530it in forum 5 Series BMW
    Last Post: 02-15-2004, 09:05 PM
