G'day all,
The struts on my '95 touring are all shot to hell, so neither the tailgate, nor the window, stay up when opened.
The (unique) tailgate struts on a touring run at about $110/pair and the hatch/glass ones are a lot less. If I acn get them all off I could get them recharged and save a heap, so I was having a look at how to swap them out...
The tailgate struts are easy as they are external- ie their fasteners locate within the hatch-jam. However the hatch/glass struts recess back into the roof cavity and look to be another story as there seems no easy way to get to their retainer clips.
I hope this story doesn't have a 'BMW process manager's' ending, but when you end up back on the forum for advice, it usually does. Here goes...
I've already removed the interior panels to see if there is internal access to the strut retainers (duh! Zat vud be too easy mwuahahhhahaa!).
All I can get to are two big bolts on each side which probably locate the tailgate hinges and would allow one to remove the whole hatch. Now I'm guessing here, but it looks like one could remove them and take the whole hatch glass, hinges and all off with a couple of helpers. (Mental note; get beer!)
Has anyone done this before and could help me get this planned? Q1: Once the hinges are free of the body, does the whole hatch slide out? I wonder how one should deal wth the wiring harness - do you have to remove the harness first?
Q2: Since there are two harnesses and they require dissassembly of the hatch to remove, I expect they are part of the procedure
Since the mesh sheath around each harness needs repair, I want to do this anyway.
Q3: Is it easier than it looks? (I know it sounds naiive but I had to ask as this all looks a whole lot harder than it probably sounds)
Of course I am hoping not...
