Results 1 to 3 of 3
Thread: Rear sway bar issue
    Sep 2007
    Michigan
    Default Rear sway bar issue
    I have Racing Dynamics front and rear sway bars. The back mounts on the trailing arms have wallowed out to the point that the links are quite loose and emits a very annoying rattle. Do I need to weld a fender washer on each side to restore the original hole location or is there something else to try? I can wiggle the sway bar links quite a bit by hand. I have H&R springs and adjustable Konis.
    sounds like the bushings have worn out, just replace them with new and good to go.
    Sep 2007
    Michigan
    The bolts move up and down on the brackets welded to the rear trailing arms. I think it's more than just bushings. That would be too easy. Although you get a "too easy" project at least once in your car life don't you? I'm thinking the holes are well wallowed and elongated. I may have to fabricate complete brackets that are more suited to the application.
  1. Rear sway bar issue
    Last Post: 07-09-2009, 09:59 PM
  2. Does a bad rear sway bar link
    By BMWCCA1 in forum 5 Series BMW
    Last Post: 03-11-2008, 12:39 AM
  3. Rear sway bar Links-Help!
    Last Post: 09-23-2007, 03:58 PM
  4. 92 e34 with broken rear sway bar both sides....HELP!
    By mvbrian in forum 5 Series BMW
    Last Post: 01-15-2006, 01:35 PM
  5. Front or Rear Sway Bars?
    By Hector in forum 5 Series BMW
    Last Post: 07-06-2004, 07:12 PM
