Results 1 to 2 of 2
Thread: Crank position sensor. How cause inermittent stumble????
    Apr 2004
    Default Crank position sensor. How cause inermittent stumble????
    Crank position sensor How cause intermittent stumble????
    Some reports that replacing CPS solves intermittent stumble/stall problems in '89 525 and maybe others.
    Logical that CPS failure causes no start/run. But, how does it cause intermittents.
    Oldham, England
    Quote Originally Posted by Gene in NC View Post
    The CPS like an ABS wheel sensor just works by means of a small current being created by a chunk of metal moving past an arrangement of magnets and a coil. You can use a DMM to check them out but unfortunately it isnt infalliable. If the CPS doesnt send a trigger signal to the ECU you wont get a spark.
  1. Testing Crank Position Sensor
    By Kobe Diesel in forum 5 Series BMW
    Last Post: 09-03-2007, 01:47 PM
  2. Crank Position Sensor Lifetime
    By Hector in forum 5 Series BMW
    Last Post: 05-01-2007, 04:58 PM
  3. Question about Crank Position Sensor
    Last Post: 04-19-2007, 04:03 AM
  4. Crank Position Sensor 473??
    By 0dough2mnyideas in forum 5 Series BMW
    Last Post: 02-23-2007, 06:02 PM
  5. Crank position sensor
    By gsotis in forum 5 Series BMW
    Last Post: 11-03-2004, 09:50 PM
