Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Replacing radiator & water pump
    yeah no more needs to be said. drain the block as well as the radiator and bleeding it can be a real hassle also.
    Draining the block is pretty easy if you use a socket on the bolt. You flushed the system, so you're probably ok. I typically take my obligatory coolant bath under the block though :-p
    Aug 2005
    Iowa, USA
    One of the hardest steps is to release the radiator mounting clips on top. Bleeding it is second hardest.
    I once with the assumption of having bled the system, embarked on a 2 degree F night trip. After taking a steep inclined onramp, the car's shift in position dislodged an airbubble and overheated the engine. It took too much time at that temperature to continue bleeding the system, so make sure you do it right the first time
    1995 525i "Stefanie"
    Northern VA
    I changed the pump on my car yesterday. The worst part of the job will be draining the old coolant. Get yourself a large drain pan (rectangular and as wide as the radiator is ideal), and lay down some plastic and newspaper under the car before you start. Even when the radiator stops flowing, you will probably spill more coolant when you replace the water pump and the hoses, not to mention the radiator itself.
    You should be able to do everything for much less than $1100, but the parts can add up. Along with the hoses, take a look at the condition of your fan shroud. Mine was literally crumbling to pieces just by touch. I tried to re-use it, but ended up chucking the thing and am currently waiting for the brown truck to arrive with a replacement.
  1. remove hood when replacing water pump on m60?
    By bbig119 in forum 5 Series BMW
    Last Post: 01-22-2010, 09:48 AM
  2. Replies: 0
    Last Post: 01-15-2007, 02:35 PM
  3. Replace water pump w/ radiator?
    By zhandax in forum 5 Series BMW
    Last Post: 09-06-2006, 07:49 AM
  4. Replacing Water Pump
    By ghost_ryder35 in forum 5 Series BMW
    Last Post: 07-02-2006, 08:25 PM
  5. Question - When replacing M30 water pump
    By Mitch90535im in forum 5 Series BMW
    Last Post: 12-15-2004, 09:35 PM
