see if you can return them and get Lemfoerder instead.
Changed my sway bar links to Meyle 316 060 4322/HD, took me hours as there was no where to counterhold at all on them and the bolt starts spinning inside the swaybar link after a few turns!
The self locking nuts are of inferior quality imo.. One of them simply would´nt tighten, just kept spinning and after fighting to get it off again (again no counterhold) I found that the thread inside the nut was totally gone, without me using any kind of excessive force. The swaybar link bolt was fine!
Thankfully I had some reserves of better quality and got everything tightened properly at last!
Lets see how long it takes for them to go bad.. Heavy Duty my a**..
A bit late, they´re mounted
There are counterholds! Look at the end of the threaded bolt. Cannot be seen on the pic), better than the old system which looked like this
http://bmwe32.masscom.net/johan/swin...spanner_16.jpg
Well, nothing except rubber on the ones I bought.. Under the rubber then perhaps? I didnt feel like destroying brand new rubber coverings so I got them mounted by using a plier at the bolt end to keep the bolt from turning (which will give me hell when I have to change them eventually unless ofcourse I just tigersaw´em at that point)
at the end of the threaded piece where the bolt comes on, have once more a look, a torx/inbus fits in (hexagon).
If I remember correctly. Will try to see if I have a pic of that.
Yes, it is suppsoed to have counterhold that you use I beieve a open ended 17mm wrench.
16 actually, Guys its not like I´m blind or anything.. But no matter as I already wrote I mounted them using an alternative approach!
The torx fitting escaped me Shogun, and I was looking like a idiot for the 16 spanner counterhold like on the old ones.. Doesnt make it any easier now that they´re on! Sigh..
