O2 sensor should be tested before replacing. The part is expensive enough that it warrants it.
Mechanic says i need a new MAF and O2 sensor, based on codes. I suspect the fault of these has led to a bad cat as well, but that is a different story.
Prior to spending money on these, are there any relays perhaps i should check before settling on faulty parts?
1995 525i "Stefanie"
What's the symptom? Check out the following link for my saga getting over the NJ emissions hurdle. You can test the O2 sensor reasonably easy with a fluke multimeter.
http://www.bimmerboard.com/forums/posts/628805/
'01 540it, 6/01
'03 325i 5 speed, 9/02
'10 535ix. 9/09
'10 mini 6 speed
'15 mini countryman 6 speed
poor power, which resolves after unplugging MAF, which likely makes it run rich, while likely spoiled the O2 sensor and Cat
Ditto the MAF which costs plenty. A malfunctioning MAF will cause an incorrect mixture that will set the O2 sensor code.
A code doesn't indicate need for component replacement, only that a sensor has detected a value outside of a predetermined normal range. This is a STARTING POINT for "diagnosis", a term lost on so many of today's mechanics.
Dont forget these codes could be being thrown because of an air leak... are you *sure* everything's buttoned up correctly and there's no leaks/cracks in your hoses?
I will double check all hoses for possible leaks and perform the excellent MAF test Shogun wrote about. I will check the O2 sensor relay as well. I already have a O2 sensor, any experience with the less than $300 MAFs?
