Originally Posted by
Bill R.
there is a problem with yours, undercharged or overcharged, nissan air usually is one of the colder ones out there... Nissan uses a pretty heavy duty fan clutch to pull air through the radiator /condensor assy and its usually all thats needed, if you replace the fan clutch use the nissan factory one as the aftermarket hayden/torquo/imperial all seem to be crap compared to the oe..
Still on the original fan clutch at 88k so I guess I need to see how much is in there. The "new" system in my 535i puts out colder air then the Nissan ever has & as I said when you are driving in town it is cool at best unless you switch to recirculate.
90 535im
02 R1100S, 87 R100S
76 R90/S,73 R75/5
Alfa Romeos- 65 Giulia Spider Veloce
& 66 Duetto 1600 Spider
