Results 1 to 4 of 4
Thread: Where does the vacuum check valve go?
    Abadiania, GO Brazil
    Default Where does the vacuum check valve go?
    Would someone be kind enough to tell me exactly where to connect the other end of the vacuum check valve? One en of it goes to the charcoal canister. I cannot seem to find where the other end goes.
    I have an M30 engine (1992 535i E34)
    One vacuum line going from Fuel Pressure regulator to nipple on intake manifold.
    One vacuum line from valve cover hose tee to other nipple on i.m.
    The line from the vacuum check valve should also connect somewhere under there. Does anyone have a picture?
    Yes, I have connected those two hoses. One to the FPR the other to the T on the hose coming from the valve cover. The issue is the hose from the Vacuum check valve.
    I can't figure out where that goes.
    Wait! I think I found it. There is a third nipple which in Shogun's picture shows up with a hose already connected to it, right next to the metal fuel lines. Now the only challenge is how to get the hose connected in such a tight space, but I am sure I will work it out.
    Thanks for the help.
  1. vacuum leak at M50 valve cover- 12 inHg at intake
    By werminghausen in forum 5 Series BMW
    Last Post: 06-15-2007, 09:11 PM
  2. how to check for vacuum leak?
    By ronn227 in forum 5 Series BMW
    Last Post: 03-26-2005, 08:16 PM
  3. Should fuel vapor valve draw a steady vacuum????
    By Robert K in forum 5 Series BMW
    Last Post: 07-27-2004, 12:21 PM
  4. Check engine light: O2 sensor or vacuum leak?
    By Bruno in forum 5 Series BMW
    Last Post: 03-13-2004, 07:02 AM
  5. Valve Cover gasket == vacuum leak?
    Last Post: 03-10-2004, 12:32 PM
