I did this last week -earlier post-, I removed the front bumper & the driver side headlights. I believe it is easier than removing brake booster or anything else, what's more you can remove the headlight vertical aim control behind the headlight & remove the cables passing behind, also loosening the steering cooling coil will also make it even easier. Good luck
