Results 1 to 10 of 11
Thread: Transmission Woes - The Final chapter (I HOPE)
    Mar 2008
    NY
    Default Transmission Woes - The Final chapter (I HOPE)
    Picked up the car and it never felt better. Shifts through the gears quite nicely and it even had reverse! He wants me to drive it as much as I can and bring it back in two weeks for a check up. I took it out for about 100 miles last night and it performed flawlessly. It does have the sport trans too which is never realized that was what the "A" and "M" were for.
    1952 MG TD
    1963 MGB
    1967 MGB GT Special
    1974 MGB Roadster
    1991 Ford Ranger
    1997 BMW 528I
    2000 Harley Davidson Softail
    2004 Ford Expedition
    Apex, NC
    Glad it got sorted out! Unless your trans is different than mine, that's not what the A and M are for. Sport mode is activated when you shift down out of drive into 3rd. The dash will show "S3" instead of "ED". Try it, you'll like it. Also very useful for driving in the mountains (engine braking).
    The A and M are for auto and manual. It's normally in A. If you change it to M, then it forces the transmission into a manual shift mode and locks it into the gear selected with the shifter. This is good for winter driving when you want to avoided wheel spin at stoplights (put it in M and 2nd gear), but little else from my experience. I suppose you could put it in M and shift through the gears yourself, but it's not like shifting an MG!
    Scott
    '11 TSX Sport Wagon
    '00 328i
    '78 MGB
    '08 Saab Aero
    +1 on the A/M switch. Use it for winter driving. It is not a sport mode shift selection unless you are looking to shift your way back to the mechanic :-p
    Sport mode is simple... just select the gear below 'D.' You will know the difference immediately.
    Mar 2008
    NY
    OK will do after work and thanks for the A/M difference.
    1952 MG TD
    1963 MGB
    1967 MGB GT Special
    1974 MGB Roadster
    1991 Ford Ranger
    1997 BMW 528I
    Sep 2008
    Gold Coast, Australia
    Good to hear you got it sorted out.
    Mar 2008
    NY
    Well I like the S3! You can realy feel the engine breaking.
    1952 MG TD
    1963 MGB
    1967 MGB GT Special
    1974 MGB Roadster
    1991 Ford Ranger
    1997 BMW 528I
    Aug 2005
    Iowa, USA
    vping,
    What exactly were your symptoms and what exactly did you have them do?
    My automatic shudders on hard accelarating, holds onto 1st gear too long, and has for all practical purposes no reverse
    1995 525i "Stefanie"
    Apr 2008
    Belgium
    as far as I know sport mode is different. It is a switch S on my car, It also has
    E for economy and 123 for pure manual
    Just below D is just 3rd gear.
    How do you go to the red line without being in manual? for me it is the S.
    Mar 2008
    NY
    Quote Originally Posted by mzarifkar View Post
    vping,
    I'd stop driving it ASAP before major damage occurs. I did not not have shuddering yet but the reverse was gone. When I went to the shop, the clutches were gone and has to be replaced. If you continue to drive it something could explode and cause more $$$damage than you were originally in for. I had them rebuild the box and the car is great now.
    Vince
    1952 MG TD
    1963 MGB
    1967 MGB GT Special
    1974 MGB Roadster
    1991 Ford Ranger
    1997 BMW 528I
  1. Transmission Woes: How much Trans Fluid?
    By vping in forum 5 Series BMW
    Last Post: 04-17-2009, 05:59 PM
  2. Next step in transmission woes
    Last Post: 04-13-2009, 12:58 PM
  3. Transmission woes. A recap.
    Last Post: 03-25-2009, 10:22 AM
  4. Transmission Woes
    Last Post: 10-08-2005, 11:12 AM
  5. Transmission and final drive fluids
    By suuntobob in forum 5 Series BMW
    Last Post: 04-08-2005, 05:14 PM
