I think you are just feeling the resistance from compression in the cylinders. Take out the spark plugs and it should be consistant.
indicate? what i mean by that is, when turning the motor with a wrench/ratchet, the motor will spin at one hardness for 180-270 degrees (iirc) and for 90-180 degrees it will turn with less resistance. this process alternates between harder and softer. neither amount of force is out of line for turning a motor over by hand. is this indicative or engine problems? thanks.
Yeah you'll feel resistance when turning a engine by hand if the spark plugs are still in.
