Just leave the insulation on and remove the hoses from the fittings/flanges on the ends.
You can remove the condenser, dryer, compressor and the hoses up to the fire wall with ease.
you can also remove the pipes from the firewall into the cabin, by opening the cover on the fire wall and accessing the expansion valve from under the right side dash and disconnecting it from the valve and exchanger.
