Results 1 to 8 of 8
Thread: Does the Valve Cover Gasket need to be sealed?
    May 2008
    Enumclaw, WA
    Default Does the Valve Cover Gasket need to be sealed?
    Hello,
    This weekend I am replacing my valve cover gaskets, and I was reading the service document on how to do it. The document said something about using a small bead of some sort of silicon sealing compound at a few locations. Has anyone else done this or can I get by without it, mostly because Idont know what would be the american equivilant to the compound.
    Captain Dan
    1995 530i
    1977 530i
    I use the spray tack gasket stuff by permatex, I like spray painting things. Never had a leak yet, I dont like silicone cause things can slip.
    Mar 2007
    Liverpool UK
    I used only the gasket when I done mine a while back and it's been sound since. M30 though, not sure if it's the same deal...
    1995 XJR: 4.0L S/charged straight 6 Auto
    What... It's not broken??? I can still fix it
    I did it about a year and a half ago as described in bentley to tack sealer at a few spots on valve gasket for my 95 530 M60. That was 18K miles ago. No leaks so far.
    Jan 2007
    Dayton Ohio
    A couple months ago I bought a gasket that already had a bead of sealer on one side. I placed the sealer side down and did not add any sealer to the upper half of the gasket. Have not detected any leaks.
    Honolulu
    You need a little sealer at the points where the cam plugs are.
    Just a little permatex non hardening gasket sealer any where you have cam plugs, front cover mating points or vertical jogs on the gasket profile.
    May 2008
    Enumclaw, WA
    Alright, thanks for all the replys. Going to Schucks today to get some permatex.
    Captain Dan
    1995 530i
    1977 530i
    Aug 2008
    Pennsylvania
    M30 gasket is not rubber and is completely flat. If I were to use sealant it would be on the corners where to parts join together. M30 gaskets are completely flat unlike the M50 and M60 gaskets that are rubber and have a dip for the cams.
  1. valve cover gasket
    By wolfpack in forum 5 Series BMW
    Last Post: 02-24-2008, 04:33 PM
  2. Re-use valve cover gasket?
    By bsell in forum 5 Series BMW
    Last Post: 02-03-2008, 01:40 PM
  3. valve cover gasket job
    By pheno in forum 5 Series BMW
    Last Post: 09-03-2007, 06:57 AM
  4. Help! Doing Valve Cover Gasket
    By 530iBall in forum 5 Series BMW
    Last Post: 08-26-2006, 11:50 AM
  5. Valve Cover Gasket
    By Shaun in forum 5 Series BMW
    Last Post: 03-12-2004, 01:09 PM
