Results 1 to 4 of 4
Thread: Thermostat
    Jan 2009
    Beautiful Pacific Northwest
    Default Thermostat
    Just a silly Question about the Thermostat (Throttle Body Thermostat to control water flow temperature to throttle body) that is connected to the air filter box. Will it hurt the engine if I connected it directly to each other, Due I broke mine and need to drive about 50miles to get a replacement.
    Mar 2004
    Phoenix, AZ
    Default No problem. I did the same thing years ago....
    Quote Originally Posted by bad2buck View Post
    Just make sure you don't have a leak or you will eventually overheat your engine since it uses the coolant flowing from the radiator. This device is to get the throttle body heated up in case of a cold day. I live in Arizona so I could pretty much bypass it and plug the hole in the air filter box.
    JD
    Check the coolant passage in you throttle body. There's a good chance that it is completely plugged with deposits. That's what we found on my brother's M50 engine. I guess that there is not much circulation through that cooling circuit because the airbox thermostat only opens during cold weather.
    Aug 2008
    Pennsylvania
    If indeed it is clogged use some type of drain cleaner. Make sure you only use it until water starts to flow out the other side because you don't want to damage the TB.
  1. Thermostat Q
    Last Post: 07-13-2010, 07:50 AM
  2. -=(Thermostat)=-
    Last Post: 07-30-2007, 07:43 PM
  3. 525 thermostat
    By yaofeng in forum 5 Series BMW
    Last Post: 08-18-2006, 08:54 AM
  4. Thermostat, what do u think?
    By rockyfeller in forum 5 Series BMW
    Last Post: 11-23-2005, 01:19 AM
  5. Thermostat
    By spitfire in forum 5 Series BMW
    Last Post: 12-19-2004, 12:09 AM
