I've got the pan off. I had to remove it with the dipstick tube as the large compression fitting was too tight and I did not want to bend anything.
Are the two small screws that hold the filter into place, metric Torx? I have a 30 and a 25 and each are too large and small respectively. Metric Allen will not work either.
Things to note - Trans fluid is seemingly decent looking. Sludge in pan is not so I am hoping that it is still just a clogged filter that is causing reverse not to work.
What do I do about this Torx situation?
1952 MG TD
1963 MGB
1967 MGB GT Special
1974 MGB Roadster
1991 Ford Ranger
1997 BMW 528I
2000 Harley Davidson Softail
2004 Ford Expedition
I did not know there was a T27. That'll probably do it.
1952 MG TD
1963 MGB
1967 MGB GT Special
1974 MGB Roadster
1991 Ford Ranger
1997 BMW 528I
Yeh you just have to get the right torx bit. The filter comes off really easy.
btw my reverse problem was not really clutch pack related, the seals were rock hard so no hydraulic pressure could be made as it would just leak. This is due to just old age.
This is what I have been trying to find out. If changing the filter does not work, I'll like to give the seals a go. How do I change those and what resource can I use to change them. I've heard people talk about them but I have not been able to find out detailed info.
1952 MG TD
1963 MGB
1967 MGB GT Special
1974 MGB Roadster
1991 Ford Ranger
1997 BMW 528I
If changing the filter doesn't work then changing the seals means you pretty much rebuild your whole transmission. Because to change the seals inside the auto you gotta strip every part/clean and replace seals/gaskets the put it back together. **** you wouldn't go to all the effort and not change the clutch packs and everything right? its like while your there you might as well do it.
Is that a feasible DIY job?
1952 MG TD
1963 MGB
1967 MGB GT Special
1974 MGB Roadster
1991 Ford Ranger
1997 BMW 528I
as you disassemble lay it all out in order making sure not to flip anything up side down. It's just a big gray mystery box when it comes down to it. Read up on it before trying so you make sure you have any special tools and tricks before attempting it. Have a service manual and all parts ready to replace. I would try to do it all in one day so you dont forget anything during the process.
The guy who rebuilt my tranny showed me some big o ring looking seals that must've came from inside the housing or somewhere big cuz no way in the world would it belong in the valve body.
e.g. parts 2 and 3 are the big o rings, they get real hard and dont seal good anymore.
http://www.realoem.com/bmw/showparts...57&hg=24&fg=15
Anyways yes i know you can drop the Valve body with the box still in. Sometimes that just needs a rebuild and your set to go.
