Results 1 to 3 of 3
Thread: Dtc 1222.
    O.C.
    Default Dtc 1222.
    New exahust on car after oem replaced. Tampered with idle air control valve, AFM. Replaced O2 sensor, TPS is adjusted properly. Leaning towards AFM as I messed with it. Any thoughts or direction greatly appreciated.
    Known symptoms, hesitation from a stop to acceleration. Low power, slow acceleration at WOT. Rough idle in park, but ok in gear.
    Thanks.
    O.C.
    Update: Replaced Throttle Body, Idle Air Control Valve, and AFM with used components from salvaged cars. Runs much better!
    Once and a while check engine light comes on and 1222 stored. Checked stock exhaust from manifolds to new exhaust pipes(no leaks found).
    No vacuum leaks found, just recently adjusted valves to .12"- no change in running.
    I am going to perform a comp. test and then cyl leak down test within the next two weeks.
    intake leak... i need to fix one that is a micro but persistant.
  1. Almost had 2 months of not 1222....
    By Golgade in forum 5 Series BMW
    Last Post: 04-15-2010, 10:26 PM
  2. I think 1222 is Gone.......
    Last Post: 02-12-2010, 12:30 PM
  3. Throwing Code 1222
    Last Post: 10-27-2008, 12:02 AM
  4. Error code 1222
    By nmwaldron in forum 5 Series BMW
    Last Post: 09-22-2006, 05:28 PM
  5. M20: Bad ICV consistent with 1222 code? nt
    By Warren N.CA in forum 5 Series BMW
    Last Post: 06-14-2004, 03:53 PM
