Results 1 to 10 of 11
Thread: Deutsche Parts (ebay seller) ?
    Jul 2007
    Youngstown OH
    Default Deutsche Parts (ebay seller) ?
    Has anyone bought any of their parts from this store?... They seem too good to be true as far as price. I am looking to replace control arms and if the kit is this cheap Ill replace it all. It has the e34 M5 upgraded control arms. I checked part numbers with real oem and they seem to be true.
    http://cgi.ebay.com/ebaymotors/BMW-E...Q5fAccessories
    Stock control arms cost $100 a piece from pelicanparts
    Tickin' Red Bomb
    That is - what I have read on another board- FCP Groton with another name.
    You get what you pay for.......
    Pelican parts will sell you good stuff, same like BMA, Autohaus Arizona and other will reputed shops.
    EXCEEDS OE SPECIFICATIONS
    Ask them the question: they why do you not inform the actual maker?
    Is it Lemforder, Meyle, QH, or a no name brand, or a name which the cheap suppliers/makers print on it when you order a min. of 100 sets?
    Long Beach, CA
    I stick with Lemfoerder parts, usually bought @ BMA.
    Honolulu
    FCP = Hamburg Tech
    which = do it over at 5k
    May 2006
    NH
    I recently replaced the Center drag link and upper thrust arm bushings.. while searching for Lemforder I did not find any of these items available from them. I ended up with the center link from TRW and the bushings from Sachs. Pelican called TRW OEM for the center link and i figured Sachs has a good rep for their shocks and I recently used their rear shock mounts but the M5 bushings i was replacing were Lemforder. I should point out they needed replacing I believe mainly due to the heavy oil leak which was constantly soaking the left bushing so as that weakened sooner than normal it allowed more stress on the other allowing it to crack sooner .. I replaced them last just over seven moths ago or apx 30K miles. The last M5 bushings I used,also Lemforder I kept for about a year. Maybe the oil leak was less but still evident .. I went with the 750i bushings this time..everything else was fine so with brand new tires and a BMW Dealership alignment she is her old beautiful self again oh I may as well include that while having the Oil and power steering fluid leaks repaired They resealed the Intake manifold w/ new manifold cover , new water Pump, radiator, drive belts, , spark plugs, coil boots, and one pulley was cracked so it was replaced. They checked the oil pump which was OK and torqued the bolts so new seal on the lower pan.. They told me i was wise getting the water pump done, there was play in the impeller meaning of course the bearings could have thrown up at any time. Reason for the new rad was the hose neck was craked.... so back at full power with perfect straight and true tracking.. just seriously needs a paint job.
    1995 540i Manual build 1/95
    TRW is OEM for center drag link. When I pulled mine out... it said TRW along with BMW insignia. I have no problem with TRW product... they are good.
    Right now, I have two complete sets of Meyle steering components... so far so good. One on BMW and one on Mercedes.
    Deutche Parts is FCP Groton. I have their dogbones.
    FCP = ****ing Crappy Parts
    I did 3 rounds of replacing their thrust arms before waking up.
    Quote Originally Posted by Blitzkrieg Bob View Post
    FCP = Hamburg Tech
    3 times?!... I only got their dogbones. My thrust is Lemforder... entire steering is Meyle.
    Honolulu
    Yeah,
    The easy stuff the like dogbones sway links etc. I go cheap, because they are so easy to replace.
    The other stuff is all lemforder, sachs, boge TRW or moog
  1. Never Buy From This Sh*tty Seller... >=(
    By BMW4LIFE in forum 5 Series BMW
    Last Post: 07-10-2010, 05:41 AM
  2. Opinions on Ebay seller goods
    By Kobe Diesel in forum 5 Series BMW
    Last Post: 10-14-2006, 10:40 AM
  3. question re: ebay Bilstein seller
    Last Post: 08-16-2006, 05:58 AM
  4. OT- Another best-seller for Bangle?!?
    By granit_silber in forum 5 Series BMW
    Last Post: 08-10-2005, 07:37 PM
