Thanks, glad to be of some use.
The soldered wires are the speaker level outs (black is +, green is -) from the head. You can solder the + to the plug input board or run the wires directly. The '-' is the real question mark. There is something I don't understand about how the factory system does the Front/Rear fade and it involves the way the speaker grounds are shared L and R. I would try splicing each side together first and using the factory wires but if that doesn't work you have to run new wires to the head for the speaker grounds.
I think 16 ga wire is good- use speaker wire, not power wire.
I believe the black and blue wires are part of that factory amp and mine is slightly different - I don't know what they do.
And now that I have tried it three times, I would suggest it might be easier soldering to the underside of the board, not at the pins.
Anyone else have this technicolour equalizer?
...this diagram comes in very handy...
good luck buddy!
