Take another good look, you shouldn't be on the bump stops.
Mine are fine with just the last ring cut off the bump stop
got the front eibachs installed.
i cut about 1.5" off the bumpstops. here's what it looks like.
i'm riding on the bumpstops. those of you with eibach springs, how much did you cut off your stops? i'm fine with cutting off some more, i'm just afraid that if i do now the car's just gonna be slammed. is somethign wrong? or did i cut just enough to make it ride on the bump stops but that also happens to be the correct ride height.
89 Mazda MX-6 GT :: 78 Suzuki GS550E :: 90 BMW 535i/5 :: 02 BMW 330i :: 97 Jeep Cherokee Sport
no i am. i double checked. deffinitely laying on the stops.
but its literally ON it. like...there's no room for movement if i press on the front of the car.
I'm just having an Eibach Pro Kit installed today.
You need to have movement when you push down on the car - no movement is not normal / healthy. What shocks are you running? I have Bilstein Sports with my Eibach shocks, and they have an internal bumpstop - so I cut out the stock bumpstops completely.
At first I mistakenly kept the stock bumpstops, and the ride was awful.
i'll do some messing around tomorrow probably. had a funeral today and work in a couple hours so no time today.
