Results 1 to 5 of 5
Thread: ICV?? Cold start issue
    Feb 2009
    Default ICV?? Cold start issue
    Hi Guys,
    I have searched and find nothing resembling my query.
    This has happened to me twice with the 540i so far, on a cold morning (Cape Town cold = 15 degrees Celsius) the car cranks over and starts perfectly, but the the idle does not stabilize, it merely just slows down until the car cuts out.
    As soon as the car warms up a little, it idles normally.
    I have not cleaned out the ICV yet, could this be the issue?
    could be, clean it out good until it turns freely then reset the computer and see how it acts.
    Feb 2009
    I'm pretty new to e34's, so excuse the stupid question, but can I reset the computer without the use of a reset tool?
    Nov 2006
    Germany
    Quote Originally Posted by freerider View Post
    Sure, just unplug the engine computer for a little while, then plug it back in.
    I know the six cylinder cars' engine computer is in a black box on the right side in front of the fire wall.
    Others may suggest undoing the battery (which is a good excuse to clean the terminals) but then you loose your radio settings and what not...
    Brian
    Feb 2009
    right so i cleaned the entire throttle body and IAC, car idles 100 times better now, the valve didnt even move when i took it out and was black inside.
    I also found the cause of the cold start/stop issue, there is an air leak at the back of my intake manifold, I suspect the gasket might be broken, that will be done by the indi shop though.
    I will also have belts done at the same time, noticed they are quite cracked up.
  1. Mystery cold hard start issue – 89 525i M20
    By RonnieB in forum 5 Series BMW
    Last Post: 02-01-2011, 02:52 PM
  2. SEMI OT: VW cold start issue..........
    Last Post: 12-06-2007, 10:57 AM
  3. center vent cold air issue-Help!!
    Last Post: 12-03-2007, 11:26 PM
  4. 1993 525iT rear wiper issue, cold running
    By calmloki in forum 5 Series BMW
    Last Post: 02-03-2006, 08:16 PM
  5. Cold start valve?
    By guy in forum 5 Series BMW
    Last Post: 04-04-2004, 04:14 PM
