Just found this site, exiting stuff they have, the one-stop-shop for the transmission repair maniacs like us:
Welcome to Makco Distributing the complete source for all your Transmission Parts needs. Transmission Parts - Automatic Performance Parts - Rebuild Kits - Coolers
Commonly asked questions
What parts come in your transmission rebuild kits?
These are not retail packaged kits but are the same professional quality, name brand kits we sell to our largest transmission customers.
Transmission Overhaul kits
Include: OE quality paper gaskets, rubber lip seals, O rings, pan gaskets (cork or fiber), metal clad seals, and sealing ring kit (metal or teflon sealing rings depending on unit). Some late model transmissions use reusable Hard Molded Rubber pan gaskets & case gaskets. The kits descriptions will list if these special gaskets are included in the indivudial kits.
We are proud to be suppling TransTec ® Overhaul kits as our main line of overhaul kits.
TransTec the aftermarket business of Freudenberg-NOK, original equipment quality and design for the aftermarket.
Our other premier suppliers are Precision International® and O.E. ZF® for your Import Transmission kits.
Transmission Banner rebuild kit
Include: Transmission Overhaul Kit, and a standard set of friction clutch plates.
Most kits will include BorgWarner friction plates. Some applications will use OE Raybestos, Dynax, Allomatic, ZF and Honda as required.
Transmission Master Rebuild kit
Include: Transmission Overhaul Kit, standard set of friction clutch plates and a standard set of steel clutch plates.
Overhaul kits, Banner kits and Master kits DO NOT come with bands, bushings, modulator, servos, sprags, shift kits or filters. Order these parts separately as needed.
The most often asked question is:
What parts do I need to rebuild my transmission with and exactly how much will it cost.
There is no simple answer to that question!
First YOU must determine what transmission you have in your car or truck.
We have no idea if the transmission is original to the car or has been rebuilt, modified or changed.
You can look at our Vehicle Transmission Index as a guide, but YOU must verify what is actually in your vehicle.
We do not know what is wrong with your transmission, so we can't tell you what is needed on every rebuild job. We can only suggest to you what should be used for a general rebuild.
Depending on your transmission
The basics of every rebuild should be:
Master kit ,Filter,Band (s), Bushing kit,Washer kit, Modulator
Technical Manual
Replace as needed:
Sprag (s), Bearing kit,Solenoids and switches, Hard parts as needed.
Torque converter
Upgrade as needed / wanted:
Shift kits or reprogramming kit, Pump kits, Servo kits, Updated planets as available
Some of these parts are not used in or available for every transmission.
The most common items are listed on the web site under the specific transmission.
The prices are listed for 99% of the items (except for some Special Order parts) You, as the final user are the final judge of what you should order and use for each application.
Notice: Information, descriptions and part numbers contained on this web site have been carefully compiled from many industry sources known for their accuracy and reliability, but we do not guarantee its accuracy. You, as the final user are the final judge of what you should order and use for each application. We cannot describe every part in long detail. Many parts have been upgraded, improved and modified from the original OE design. You should not expect to rebuild a transmission with a $50.00 overhaul kit. There are many other parts that you may need to replace. You will need to order these parts as needed.
BMW Transmissions Quick Reference.
You should use this Vehicle Transmission Index as a starting guide only! This is the information we have on the standard factory applications. Some vehicles may have been special ordered with different transmissions. Also check to see if the transmission has beed rebuilt, or completely replaced before.
http://www.bulkpart.com/
they also have a lot
http://stores.shop.ebay.com/CT-POWERTRAIN-PRODUCTS
pls add links if your know a good transmission parts shop
