I had to replace a drive shaft with rebuilt one because U joint was no good and they are pressed on. Rebuilt shaft was 175.00 and had center bearing on it. Not sure if that is your problem but its possible.
My main question is: How do you know if a drive shaft is bad? What actually goes bad on it? Can it be rebuilt? Cost?
I have replaced the centering bearing twice in about 6 months. Yes, I did correctly pre load it. I measured it out and everything. The guobo has been replaced in the last 6 months as well.
I am experiencing a prettyvibration throughout the vehicle, in gear or out of gear. Ive checked to see if everything is tight (it was), but I didnt check the centering bearing again. Could a bad driveshaft be ruining the centering bearing over and over again?
I dont think its the tranny (5 speed), because the vibration (sound as well - w0w0w0w0w0w) does not go away regardless of if Im rolling in neutral, going 80+ on the freeway or driving streets.
As im accelerating it almost feels like a wheel shimmy sometimes (happens in third gear around 3-4 rpms). Any ideas or suggestions would be greatly appreciated
1990 BMW 525i m20 SOHC 5-speed 140k miles, black on black, stoc
http://www.born-today.com/Today/pix/tyson_m.jpg
MAN WHAT?!?!...
Everyone has to go on U-Tube and watch mike tyson interview
How can you tell though, from a visual inspection that the driveshaft is bad?
Do you feel it in the driving when the driveshaft has a problem?
How is it diagnosed?
What does it look like when the U joint is bad?
Thanx
MAN WHAT?!?!...
I just replaced the driveshaft on my sons 7. Once the center bearing is loose you can tell very easily if any of the bearing are toast. I the case of the 91 735i we had to replace the entire driveshaft because there are no replacement bearings available. Shaft came with center bearing...$400.00 USD
The U joints get "notchy" and if totally neglected will seize up. The CV, on those so equipped, can lose its grease and die as well.
The center support failure could be because of an inferior replacement part, or because one of the joints is bad and putting undue stress on it....
